Repair and disassembly guides for camcorders designed by DXG.
Camcorder won't hold a charge
Hey there, in need of some help. I have a DXG-5B6V HD handheld camcorder that won't hold a charge. It was sitting in my mom's garage brand new in the box for years and I finally claimed it.
It takes a 2gb SD card, requires 4 triple A batteries and a cable charge. The SD card is brand new, as are the batteries, and the charging cable isn't damaged.
While it's charging, the screen will occasionally turn on and display a single storage option or a Direct Print option. Selecting the storage option will make the screen go black. It can sit and charge for hours and hours, but when unplugged the screen will turn on for about 30 seconds and then the device will die.
What is wrong with it? Nothing is corroded or damaged. What can I do?
Add a comment
1 Answer
Most Helpful Answer
Hi @worm2539
What type of batteries are you using in the camcorder?
If using rechargeable batteries then they cannot be recharged by connecting a USB cable to the camcorder's USB port.
They need to be recharged out of the camcorder using an appropriate charger for the type of rechargeable battery i.e. NiMH or Li-Ion.
The USB port is for data transfer only. Here's the user manual if you wish to verify this.
Have you checked that you inserted the batteries correctly, polarity wise?
Score 1
Add a comment
Add your answer
Worm2539 will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 22
All Time: 167
