Won't Charge Past 0%
I had been using my laptop perfectly fine, when suddenly upon, flipping open the laptop, it was completely dead, no sign of life, not even the battery indicator lit up when I plugged it in. I stuck a pin in the hole to reset the battery, and that worked so that when I then plugged it in, I was able to turn on the laptop. However it stays at 0% and won't charge at all. (if this helps, I don't believe I had plugged in the laptop in between the time that it was working fine and the time I opened up do a dead laptop) Please help, thanks!
Add a comment
1 Answer
@yozid two things that come to mind. First a bad battery, consider replacing the battery. A depleted battery can no longer be charged. A bad battery should not prevent your computer from coming on, if it is connected to the AC adapter.
After that it i possible that you are having issues with charging circuit on your motherboard. If a new battery behaves the same way, then it is time to take a really close look at the motherboard. For that, we would need to A. know the exact model of the board. It'll be written on it (most of the time it is printed on the side that aces the keyboard) B. we would need to see your motherboard, both sides. So post a couple of well focused, large enough images so we can zoom in and try to help you figuring this out. Adding images to an existing question
Start with a new battery. It's a lot easier. To work on it, download the hardware maintenance manual from this page Lenovo IdeaPad Slim 7-14ITL05 under the Document heading.
Add a comment
Add your answer
yozid will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 11
All Time: 206
