The GameCube is Nintendo's fourth console gaming system. Repair is simple and requires only common tools.
3rd party Gamecube Memory Card doesn't read saves
Whenever I try to use the memory card in a game it says it's damaged, and in the settings it says: "The device inserted in Slot A cannot be used."
The only thing that happened to that memory card was me moving it from my Gamecube to my Wii occasionally.
1 Comment
Which model of GameCube is it? (If it has a Digital AV out, it's a DOL-001. If not, it's a DOL-101.) I'm not sure if it would make a difference, but it might. Does it still function on the Wii? That could also make a difference.
by
Add a comment
1 Answer
Chosen Solution
Hi!
Do other memory cards works fine?
I would try this first before you are going to replace the front panel.
If so, then I would replace the memory card and get rid of the broken one. It won't be easy to fix that one unfortunately...
Score 1
2 Comments:
I did end up replacing the memory card with 2 old used official ones from eBay which are still working now a year later.
by
Glad that a new memory card did work! Have a great day :)!
by
Add a comment
Add your answer
Nirby 74 will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 25
All Time: 213
