Repair and disassembly information for the Samsung Galaxy Note20 Ultra Android smartphone. Released in August of 2020.
Why won't my Note 20 Ultra get service?
My phone(N20U Exynos) isn't receiving a signal, so no calls/SMS/Data or even Emergency. According to *#0011#, it's telling me that 2 parts have gotten bad.⏎ but I have no idea what these 2 parts are, and idk where they are(remember, I am on Exynos and my motherboard parts are different than the iFixit teardown of the N20U)
2 Comments
Hi @damaj301damaj
What is the model number of your phone e.g. sm-N985?
Is the phone locked or unlocked?
If unlocked can you try using a different known working compatible SIM card to check if there's a signal?
Has the phone been dropped or gotten wet at all?
by
Hi @jayeff, my phone is an SM-N985F/DS.
Phone is unlocked and works with all carriers, I tried 3 simcards that are known working but they didn't work.
no the phone wasn't dropped nor it got wet, I had service, now suddenly out of service
by
Add a comment
1 Answer
Chosen Solution
Hi @damaj301damaj
Can you charge the phone OK using a USB-C charger?
Also try using the voice recorder app (record in stereo) just to see if that works.
Trying to prove if the problem is related to the charge port board e.g. loose flex cable connection, as some of the antennas for the phone are located on this board
If the above work OK then it may be a systemboard problem. Here's the SM N985F Service Manual that may help.
Go to p.38 (of 55 pdf) to view the GSM, WCDMA, LTE troubleshooting flowcharts and check if it leads to where the problem may be.
There are board layout diagrams on p.2→p.5. Use the search function in your browser to find the location on the board(s) of the components mentioned in the flowchart. You have to zoom in a lot to see them.
Score 1
1 Comment:
Yep, I can record using the voice recording app(both mics) work, and the USB-C charging/USB connection with PC/AA works perfectly, ama check the document you sent and see what to do
by
Add a comment
Add your answer
Mohamad Damaj will be eternally grateful.
Past 24 Hours: 3
Past 7 Days: 10
Past 30 Days: 40
All Time: 871
