The LG Velvet is a flagship slate Android smartphone released by LG in 2020. Identifiable by model numbers G900/910, followed by a version/carrier specific character set.
Can't see wifi Connection. what would I do
Can't see wifi Connection. what would i do
Add a comment
Most Helpful Answer
Hi @arjie
Try using the phone's WiFi as close as possible to your home network router i.e. <10cm and check if it detects and connects to the network and if the connection remains stable.
If it does, there may be an antenna problem in the phone e.g. loose or faulty.
Here's an image taken from this teardown video showing the antenna connections.
(click on image)
Score 1
Add a comment
If your phone can't see a Wi-Fi connection, the first steps are to check if your phone's Wi-Fi is turned on, ensure you're not in airplane mode, and then try restarting your phone and router; if that doesn't work, you can try forgetting the network and reconnecting, checking for network updates, or even resetting your network settings on your phone.
Add a comment
Turn Wi-Fi on in the upper right corner to see available networks
Add a comment
Add your answer
arjie will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 51
All Time: 370
