The DJI Mini 2 is a small drone that was made in 2020 by DJI. The DJI Mini 2 has 4K/30fps video and 10km 720p/30fps video transmission.
My DJI mini 2 controller won't charge
My DJI mini 2 controller will not charge
Add a comment
If your DJI Mini 2 controller isn't charging, first check that you're using the correct charging cable and power source, then try using a different cable and charger to see if the issue persists; if it does, the problem might be with the controller itself and you should contact DJI support to potentially send it in for repair.
1 Comment:
this forum is called " I fix it" not "DJI repair shop fixed it" :-)
by
Add a comment
This is somewhat outdated now I guess, but did you fix it in the end? If you're a technician you've probably taken it apart?
Add a comment
Add your answer
Timothy Howard will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 9
Past 30 Days: 37
All Time: 388
