A machine of the family of BSH household devices built by the Swiss OEM company Eugster. There are many similarities in its construction with machines by Bosch, Melitta, or Nivona.
Error1 & outlet valve leaks
Hello,
First, thank you for the clear tutorial on supporting the circular economy.
  • My 15-year-old Surpresso is showing "Error 1." Could you help me fix this issue?
  • Since the outlet valve was leaking, I cleaned it and replaced it with a new one. However, I am still experiencing a leak from the outlet valve. What would you recommend?
Thanks,
Tonny
Score 1
Add a comment
1 Answer
Most Helpful Answer
The Error 1 issue needs to be resolved by Siemens themselves. There's apparently a way to get to the error to see what it's for in the diagnostics menu (Menu -> Diagnostics -> Alarms -> Click on Alarm -> Help) should give you a bit more info but usually it just says to contact Siemans.
As for the leaky valve, if the leak is coming from the valve itself it's most likely that an o-ring isn't sealed properly or has gone bad. You could try getting another o-ring if the valve you bought didn't come from one, or you could try to re-attach the valve so it doesn't leak.
Score 1
2 Comments:
Thank you very much for your support!
The Error 1 because the temperature from external CTN 72° vs. >80°C+ - Boiler R=37Ohms almost 1400w+/230v, thermal protection okay...what should be the probleme since no other regulation on the boiler?
I replaced the drainage valve gaskets, but I’m still getting a significant leak from the valve. 🤔 I’m going to check the assembly again, particularly the drainage that connects to the brewing unit.
by
как решили проблему?
by
Add a comment
Add your answer
ftonny will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 37
All Time: 293
