The Sony Smart Watch SW2 is a smartwatch created by Sony. The model number for the device is SW2 1271-4651.1.
The smart watch doesn't turn on
I was using it for long but now the watch doesn't turn on after charge. Plz advise
Score 1
Add a comment
1 Answer
If your Watch isn't turning on after charging, here are some steps you can try to troubleshoot the issue:
Check the Charger and Cable: Ensure that the charger and cable are functioning correctly. Try using a different USB cable and charger if possible.
Charge Longer: Leave it plugged in for at least 30 minutes to an hour. Sometimes the battery might be too depleted to power on immediately.
Force Restart: If the watch is unresponsive, try a force restart: Hold the power button for about 10-15 seconds until the watch vibrates.
Software Issues: If it powers on but doesn’t function correctly, it might need a software reset or update. You can do this via the companion app on your smartphone.
Add a comment
Add your answer
Nayak will be eternally grateful.
Past 24 Hours: 13
Past 7 Days: 20
Past 30 Days: 51
All Time: 734
