Up to 20% off select tools
Repair guides and support for 20" Intel iMacs by Apple.
Won't boot up
Circle with line through it
Add a comment
1 Answer
Well that’s not a good sign, but a repairable one! Either the OS is missing or damaged on the drive or the drive its self is damaged and will need to be replaced.
As Apple produced a very versions of this model you’ll need to figure out which is yours 20” iMac listing
As an example review this guide on how to gain access to the drive iMac Intel 20" EMC 2105 and 2118 Hard Drive Replacement it will give you the general idea what’s needed. Be careful as this series uses an older version of SATA interface so you will need a drive which supports the older version SATA II (3.0 Gbps) if the drives spec sheet doesn’t list this you’ll need to find another drive.
Now the tricky part! Hopefully you still have the CD’s/DVD’s that came with the system as you’ll need the OS installer disk to re-install the OS and depending on what your system is your options maybe limited as to the highest version you can run on your system.
Add a comment
Add your answer
Irene Villanueva will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 10
All Time: 144
