My laptop won't turn on
My laptop won't turn on but the power indicator is on, The power indicator lights up, but only the power indicator light lights up and when charging the laptop, a beep will sound.
Add a comment
1 Answer
Most Helpful Answer
Hi @finofficial
Try the following and see if either one resolves the problem.
a). Turn off the laptop if it is on and disconnect the charger (if connected).
Remove the battery from the laptop and press and hold the laptop's power On button for 15 seconds and then release it. Reinsert the battery, reconnect the charger and turn on the laptop and check.
b). Turn off the laptop if it is on and disconnect the charger (if connected). Remove the battery from the laptop and then open the laptop and remove the coin cell RTC battery from the motherboard. When the coin cell battery is out, check its voltage. If it is <2.5V DC or > 4-5 years old, replace it. The battery type number is stamped on the battery itself. Here's a video that may help. The coin cell battery can be clearly seen at 2:55 minutes into the video on the lower left side of the motherboard. Reinsert the coin cell battery, reassemble the laptop, reinsert the main battery, reconnect the charger and turn on the laptop and check.
If still no good then there's a problem on the motherboard and further testing would be required using the schematics to find out what's wrong.
Score 1
Add a comment
Add your answer
Fin Official will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 5
Past 30 Days: 15
All Time: 205
