The Philips HD9252 is an air fryer designed by the Philips company.
My Philips air fryer, cannot close
The basket cannot inject to the machine, there is little button click when you put the basket (inject to the machine), after that you can start to on the machine,
The plastic on the bottom edge of basket the air fryer is eroded, so that when you insert it, it doesn't press the click lock button, how to fix it, even if to change, I don't know where the store sell the bottom part
Add a comment
1 Answer
Most Helpful Answer
Hi @mardianana61849
If you mean that you need a new inner basket, search online for 300005954981 to find suppliers that suit you best. (examples only)
Score 1
2 Comments:
The question is not about a new basket, it is about the switch
by
@match49275
The OP said " the plastic on the bottom edge of basket the air fryer is eroded, so that when you insert it, it doesn't press the click lock button..." so I therefore suggested that a new basket might fix the problem.
If the basket is eroded repairing or replacing the switch won't fix it. The basket operates the switch,
by
Add a comment
Add your answer
Mardiana Nasution will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 7
Past 30 Days: 58
All Time: 939
