Model A1001 or A1025 / 667, 800, 867, or 1.0 GHz G4 processor
Won't boot passed blue screen?
Can only get in single user mode.
Score -1
Add a comment
Chosen Solution
Try booting in Safe Mode by holding down the Shift key. What system are you running. Start up from the installation disk by putting the disk in the CD drive and holding down the "C" key while hitting the start button the run Disk Utilities and see if you can repair the system.
Score 1
1 Comment:
Too fast for me--like the idea of booting into the safe mode. Ralph
by
Add a comment
Most Helpful Answer
If possible boot with your OS disk and run disk repair until it finds no problems. With luck that will clear the problem. You should do a backup of your data first because you may end up needing to format and reinstall. Backup first and then repair. Good luck. Ralph
Score 2
1 Comment:
Good idea ;-) +
by
Add a comment
Add your answer
Ron will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 4
Past 30 Days: 13
All Time: 1,444
