Model A1990 / EMC 3359. Released in May 2019 with new 6-core and 8-core processor options.
one of the USB C isn't working
I used 2 display monitors and had them connected to a multi connection bar. 2 days ago I unplugged the bar because I just needed the laptop by itself. The laptop was in sleep mode when I pulled the bar out. But later when I plugged the bar in and used my displays, they won't work, and I realized that the one USB C has failed on one side. If this problem cannot be fixed by doing something Non-Hardware, then please give me a step by step how to fix the USB C port.
Add a comment
1 Answer
The USB-C port assembly is replaceable! MacBook Pro (A1989, A1990, A2141, A2159, A2251, A2289, A2338 Mid 2018-2022) USB-C Board
Sadly, it’s a bit of work as you need to lift out the logic board to get it out and the replacement in.
Replace one of the thunderbolt connector boards from the left or right side of your laptop. Image
Product
$19.99
Add a comment
Add your answer
Ashish Kumar will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 11
All Time: 138
