The smaller of Apple's MacBook Air laptops featuring dual microphones and 802.11ac Wi-Fi connectivity.
Black screen on display and external monitor
I have change the motherboard, battery works, it chimes at start but only gives black screen in the internal display and external monitor, is the motherboard faulty or is something else ?
Add a comment
1 Answer
What did the original logic board show you? I would double check to see if that is also failing in the same way. Maybe you have a different problem.
Are you sure the external display connection is good? If that’s the case then it’s likely you have a bad logic board.
Add a comment
Add your answer
Mitigations will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 21
All Time: 153
