Repair guides and troubleshooting for the Dell Dimension 2300, a desktop computer released in 2002 that uses the Windows XP operating system.
power butten don't work
Score 3
1 Comment
Power button not working
by
Add a comment
1 Answer
Most Helpful Answer
Hi @yaredtaye!
Do you have a multimeter? If so, remove the power button board from the computer and follow this guide to check the button for continuity. If the meter beeps while you push the button, it is functional. You may have to experiment to find out which line is which. If it isn't faulty, you may have a problem with the cable connecting the board to the motherboard, or the motherboard itself. If indeed it is faulty, you should be able to find a replacement board on eBay or just solder a new button in.
Good luck!
Score 2
Add a comment
Add your answer
yared taye will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 29
All Time: 802
