Washing machine door won't unlock?
My washing machine cycle came to an end. After 3 minutes it is supposed to unlock, but it didnt. It has drained all the water out, so that's not a problem. I turned the power off on the wall, and it still wouldnt unlock. How can I get my wet washing out?
13 Comments
My washer door seems to be stuck shut because an object is blocking it from inside.
by Jan Share
OK. I solved my own problem. There was a piece of clothing caught in the door. I push on the door and restarted the machine and discovered there was a piece of wash stuck in the door. I found this out by watching as I pushed. I started the machine twice and tried dislodge it and luckily I was able to before I burned out anything.
by Jan Share
Machine has stopped washing my clothes while there is water and clothes inside, now got a lock key which is not removable and I press all buttons nothing helpful at the moment, what to do in this case.
by Mluleki Hlongwane Share
My washer door wouldn't open after a spin cycle. We had to change the cycle and then it allowed us to open it but the barrel had water in it and the clothes were not spun dry
by Joanne Share
* i have Samsung washing machine the red key light on so i cant open the door at the end of circle, when i unplug the electrical plug the door open .i try to load it again there is alot of water pumped from the drain and the light sill on the machine not working .
by Nayef Mshaqbe Share
Show 8 more comments
