A1708 / EMC 2978 — Released October 2016, this entry-level MacBook Pro retains its traditional function keys (as opposed to the OLED Touch Bar). The function key version packs an Intel Core i5 and two Thunderbolt 3 ports.
MacBook doesn't start after battery replacement
Hello,
In my MacBook A1708 I replaced battery. After that MacBook doesn't start. Nevermind if charger is plugged or unplugged.
If I unplugged flex battery connector - MacBook starts with plugged charger. Do you have some ideas what gone wrong?
Add a comment
1 Answer
Chosen Solution
I would suspect the cable or the connectors have been damaged somehow so you have a short. Otherwise the battery maybe defective.
Score 1
2 Comments:
I ordered a new cable, I will let you know after replacing it if it solved the problem
by
Problem resovled. After replace flex battery connector MacBook works fine
by
Add a comment
Add your answer
Dariusz will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 21
All Time: 259
