Great vacuum and easy to repair.
Why won't my vacuum turn on?
Oreck won't turn on and handle power switch doesn't illuminate.
Score 2
Add a comment
1 Answer
Chosen Solution
The electrical connector to the switch itself may be disconnected inside the handle.
  • After the obvious try a different outlet, verify the cord is plugged in both ends.
  • The connections to the illuminated switch in the handle are pressed on. After repeated dropping of the handle onto the floor, a switch connector may have fallen off the switch.
  • Unplug the unit and remove the screws holding the two sides of the handle together. Locate the loose wire and plug it back into the switch lug.
  • Loosely assemble the handle, plug in the vac and give it a try. If it turns on tighten the screws.
Score 2
Add a comment
Add your answer
Randy Tolleson will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 7
Past 30 Days: 57
All Time: 1,864
