Up to 20% off select tools
Repair and troubleshooting guides for the Acer Aspire V3-571G-9686. This 15.6 inch laptop was released in October of 2012.
Won't charge while on
The laptop only charges when it's plugged off or when there's not much going on in the OS, tried many different chargers but it refuses to charge. It blinks the power and battery LEDs when it's on the charger.
Add a comment
Most Helpful Answer
As with many devices that use a rechargeable battery, when a charger is plugged in, the device (In your case, your computer) will take the power from the charger instead of charging the battery, which is common among many devices, including mine.
If you want to charge the battery, you will have to power off your device (computer), place it on the charger, and let it charge until full
Note: Your computer must be fully shut down or in hibernation (the process of the computer saving everything that you are doing and shutting down so that it returns when powered on, like sleep mode but it fully shuts down the computer). Placing the computer in sleep mode may not allow the battery to charge.
Score 1
Add a comment
Hi @wiiyz
It may be that the battery is failing and the charger can't do both when the laptop is turned on i.e. run the laptop and charge a failing battery at the same time.
Create a battery report to check the condition of the battery.
When you have the report, compare the Design Capacity value versus the Full Charge Capacity value in the report. For a good battery they will nearly be the same value. You can calculate the current battery condition as a percentage of its original factory condition by using the formula: Full Charge value x 100 ÷ Design Capacity value.
If the current condition is <40% you may wish to consider replacing the battery soon
Score 1
2 Comments:
@jayeff This could be the reason, but it could also be that the device can't handle both, good battery or not. I have a tablet that is less than a year old that has a similar issue but is resolved by powering off the device and letting it charge.
by Share
@jri_creator
That's not how it left the factory (reputable brands wouldn't design it that way) perhaps it could be due to software updates or it is a hardware fault.
Although it is not unknown for new batteries to fail early either ;-)
by Share
Add a comment
One useful way to check the battery is to compare the Full Charge Capacity with the Design Capacity from the battery report. Dividing the full-charge value by the design capacity and multiplying by 100 gives you the battery's current capacity as a percentage of its original specification.
For a quick calculation, you can use a calculadora de porcentagem and enter the two capacity values. This can make it easier to see how much capacity the battery has lost before deciding whether the charging behavior points to a battery issue.
Add a comment
Add your answer
Wii will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 17
All Time: 493
