Up to 20% off select tools
Nintendo Game Boy Advance, released in 2001. Repair requires only common tools and no heat.
Gameboy isn't getting enough power
I turn on my gameboy. Light flashes red then turns off. Please help. It isn't the batteries because my other gba works.
Add a comment
1 Answer
Your power switch is likely dirty. You can sometimes temporarily fix this by taking the batteries out and switching the power switch back and forth many times to rub away oxidation, but a more permanent fix is to open up the power switch and clean all the metal parts inside it with some rubbing alcohol.
Add a comment
Add your answer
Waterforests will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 21
All Time: 406
