Repair and disassembly information for the Nokia 3.1, an affordable phone with a mixed glass, aluminum, and plastic build released in June 2019.
Why does my phone's apps run slow
Like whenever I enter a app or game it will always be so delayed and the keyboard to and sometimes the app would crash
2 Comments
Malware and/or system may have too many apps running.
by
The battety runs out quickly
by
Add a comment
1 Answer
Most Helpful Answer
Hi @juniorkambale
Things to try to resolve the problem:
If it works OK when in safe mode, a downloaded app may be the cause of the problem. The trick is to find out which one. You will need to uninstall each downloaded app one by one and test the phone in normal mode between each uninstall, to check if it works OK or not. When it does the last downloaded app that was uninstalled was the culprit. A downloaded app is one that you downloaded and installed and wasn't already pre-installed on the phone when you got it.
Score 1
Add a comment
Add your answer
junior kambale will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 7
All Time: 479
