Up to 20% off select tools
8 inch tablet released in July of 2019. Came as a 32GB or 64GB model. The display is a TFT LCD with a resolution of 800 x 1280 pixels. Main Camera is a 8 MP camera and the selfie cam is a 2MP cam. The versions are: SM-T290 (Wi-Fi); SM-T295 (LTE)
My internet doesn't work
The wi-fi on my tablet doesn't work properly, there are certain places in my home where the wi-fi doesn't work, and places that do, and that's just on my device my family's devices work properly.
I wanted help with this problem.
Add a comment
1 Answer
Most Helpful Answer
Hi @vini13
Try using the tablet's WiFi as close as possible to the network router in your premises i.e. <10cm and check if it works OK and that it maintains a stable connection.
If it works OK it may be a loose WiFi antenna connection that is the problem, (supplier example only to show what the antenna looks like)
Here's a teardown video for the tablet that may help.
The antenna can be seen being removed from the tablet at ~1:51 minutes into the video.
Score 1
Add a comment
Add your answer
Vinicius will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 16
All Time: 278
