Up to 20% off select tools
The LG V40 ThinQ Android smartphone was released in October 2018. The V40 was LG's first smartphone to feature five total cameras.
Phone's USB Device Not Recognized
When I connect via USB it charges fine bur no PC I have ever connected to recognize the phone. My newer car gives the same message.
Add a comment
1 Answer
Most Helpful Answer
Hi Debbie,
There could be several reasons why your phone may not be recognized by a computer. I found an article that goes through all the possibilities and gives you solutions for them.
LG V40 ThinQ won't connect to PC? Just do this
In a nutshell, here's the list.
  1. Default USB connection type on the phone is "USB Charging".
    Change the setting to "File Transfer" or "MTP".
  2. Use Developer Options to change the default connection type as listed above so it stays that way.
  3. Try a different USB port on the computer.
  4. Check the charging cable.
    My addition: I have seen cables that are for charging only and don't support data communication.
  5. Update your MTP driver on the computer.
  6. Use the Android File Transfer app for a Mac.
  7. Run Windows Device Troubleshooter.
  8. Try a different PC.
  9. Take it to an authorized service center.
Hopefully something in there will help. Let us know how it goes!
Score 1
Add a comment
Add your answer
Debbie Carney will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 33
All Time: 1,200
