Up to 20% off select tools
Repair documentation for the 3rd generation 11" iPad Pro (model numbers A2377, A2459, A2301, and A2460). Released May 2021.
top volume button isn't working
the top volume button is stuck. is there any way to fix that?
Score 1
Add a comment
Most Helpful Answer
You'd have to remove the screen and maybe, depending on location remove the motherboard too. Then remove the plate behind the buttons to remove and clean them and the opening for the buttons. Unless the area around the buttons has been damaged. If you haven't removed a ipad screen before go real easy as there's a risk you'll break it.
Score 1
1 Comment:
Thank you. Definitely helpful but I’m not that tech savvy. Have a great day!
by Share
Add a comment
Check your iPhone's volume settings (sound settings) to make sure that volume buttons aren't disabled. To do this: Open the Settings app. Tap Sounds & Haptics
Regards,
Will
1 Comment:
Thank you - will try that.
by Share
Add a comment
my power button is not working well, it is mostly stuck. Can this be fixed?
Add a comment
Add your answer
Pam will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 25
All Time: 601
