Repair and troubleshooting information for the Lenovo IdeaPad 5 15IIL05. Lenovo's Intel-based IdeaPad 5 laptop was released in 2020. Includes device identification details, technical specifications, and common issues such as hinge and power button problems.
LCD Backlight Not Working, Brightness Buttons Don't Affect
Does anyone have the schematics for this model? I'd like see if this might be a board level issue and if so how I might fix it.
1 Comment:
Fatima N I am sure the schematics are out there but you need to identify your specific board for this. There are a few different variation even within the same model. Let us know what numbers are on your board. I would expect something like LCFC NM-D031 but we should not guess.
by
Add a comment
1 Answer
To see it it's a board-level issue, try connecting an external monitor to your laptop. Use a function key to toggle between the external monitor and your laptop's display. If the external monitor works, then it's not a board-level issue; it may be the laptop's LCD assembly. Fix it by first replacing the laptop's display inverter, then replacing the LCD panel. It's usually best practice to try the cheaper solutions first.
If neither display works, then it's probably a board-level issue. I agree with oldturkey03; it's best to confirm the motherboard type. However, these links may also be useful:
Laptop User Guide:
https://download.lenovo.com/consumer/mob...
Laptop Parts (enter the serial number for your laptop to see a list of the specific parts installed):
https://pcsupport.lenovo.com/us/en/produ...
Add a comment
Add your answer
Fatima N will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 3
Past 30 Days: 23
All Time: 2,597
