Charging port doesn't work
Hello! When the device is plugged in via the micro-USB port, the device doesn't charge. Does anyone have any experience replacing the port, or know of any other ways to fix this issue? Thanks in advance.
For info, I have tried several cables, as well as connecting to the mains and to a laptop but in no case can the device be turned on.
Score 1
Add a comment
1 Answer
Most Helpful Answer
Hi @es2k6
Here's a video that shows what to try that may help.
Score 3
2 Comments:
Hi. Thanks for the video. I just tried that, as well as updating the firmware with the bose updater. The device is recognised by the computer but still no way of turning the device on.
by
@es2k6
Here's a video that shows how to disassemble the speaker. This should give you access to the charge port and if you have a DMM (digital multimeter) you can check if the port is OK electrically and you can also visually check for any problems on the motherboard
After that it becomes harder as Bose doesn't release any schematics.
by
Add a comment
Add your answer
E S will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 15
Past 30 Days: 54
All Time: 3,240
