The Sanyo VPC-T850 is an 8.1 megapixel compact digital camera released by electronics manufacturer Sanyo on May 16th, 2008.
Why my device won't power on?
Why my device won’t power on?
Add a comment
1 Answer
@jocamera not a lot of information here. You should at minimum tell us what you have tried. I suggest:
  • charging the battery,
  • replacing the battery,
  • check the battery door to ensure it makes proper contact with the battery
  • check battery contacts
  • Disassemble the camera to the mother board and check for bad fuses or bad component on board
this guide will at least get you into the camera. Post some pictures of your mother board if you have to work on it so we can see what you see Adding images to an existing question
Add a comment
Add your answer
Cece will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 16
All Time: 608
