LG Stylo 5 is an Android smartphone that was announced in June 2019.
My phone won't charge why
How do i know if my phone is charged but just has a black screen problem?
1 Comment:
Use a USB multimeter like https://smile.amazon.com/dp/B07JYVPLLJ/r.... If you need something quicker, you can take the insulation off a USB cable, cut the red wire, switch your meter to amps, and hold the probes on the two sides of the red wire. If you see 0.5 amps or higher on the meter, the phone is charging.
by
Add a comment
1 Answer
Get a USB C to HDMI cable and plug in in. If it does not show up, you probably have a broken battery or motherboard. If it does you probably have a broken display.
Add a comment
Add your answer
Shawntay Potter will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 9
Past 30 Days: 23
All Time: 661
