Repair information for the 7" Android tablet by Samsung. Fixing this device is straightforward, and requires only common tools. The Samsung Galaxy Tab is an Android-based tablet computer produced by Samsung. The 7-inch Samsung Galaxy Tab is the first model in the series. It was introduced on September 2, 2010
Why Samsung home application has stopped unexpectedly?
process com.sec.android.app.twlauncher
Score 30
5 Comments
could you please give a few more details? is the screen frozen completely or just one app?any drop? software update? new apps added?
by
software update
by
basically i cant access anything because of the samsung home application has stopped unexpectedly error which wont disappear.
by
why it give this type of masseges again and again?
by
mine it keep say app stopped working...several apps and several times on on top of another and it installs applications by itself and the adds wont stopp popping up and dont disappear even when i try to remove them off the screen... Its crazy
by
Add a comment
Most Helpful Answer
Hi there. In order to give you more precise info we need to know if you're running stock or custom ROM? Otherwise, the general procedure would be to reinstall the Samsung Home application. If that fails, I would recommend wiping (data/factory reset) as it would probably reinstall the app along with any corrupt system files.
How to wipe Galaxy Tab:
1) With the device off, press and hold Volume Up and Power.
2) Release the Power button when you see the Samsung logo, but continue to hold Volume Up until the recovery screen appears.
3) Use the Volume buttons to navigate the menu and select wipe data / factory reset. Press Home to choose the selection.
4) Press Volume Up continue.
5) The Galaxy Tab should then go through the hard reset process.
Let us know if that helps. Good luck.
Score 4
6 Comments:
thank you so much walter.i was afraid that may tab will not work again.
by
Thank you! This worked to reboot my Tab 3. I couldn't power it off but followed the instructions and it rebooted. Now the screen is operational again.
by
I need help. I was using my phone and out of no where it locked with the message:
Unfortunately, com. sec. android. app. Samsung apps has stopped.
by
Unfortunately my volume button is not functioning, it got stuck. Are there other options.
by
I tried this a few times but the problem keeps happening again. Help please?
by
Show 1 more comment
Add a comment
Try this before you wipe your phone... suggested by other members
http://www.webburr.com/android/process-c...
and watch this youtube video for more clarity.....
http://www.youtube.com/watch?v=hBDH65cSP...
Score 2
Add a comment
Getting the same problem saying Sorry The application Samsung Home (process com.sec.android.app.twlauncher) has stopped unexpectedl
it is not allowing me to open menu or doing any function other than making calls and messages.......
Can anybody please tell me the procedure to rectify this problem,,?????
Score 1
1 Comment:
I have same peoblem my samsung galaxy s gt-i9000 i am trying to update but its no update avliab or no orgnal stuck rom i mean i cant flash my mob
by
Add a comment
ok thanks.. but my galaxy tab still hang why..? i already follow instruction from you.. any idea please..
Add a comment
This answer was originally to another question.
will this wipe all my pictures on it?
Add a comment
one app
Update
one app
1 Comment:
After a hard reset, I still have a msg stating unfortunately content home has stopped and it doesn't connect to wifi. Is there any assistance for this issue?
by
Add a comment
Workable! finally your technique saved my tab... but sadly i've lost all my lovely apps especially Smurff village.. deym~
Add a comment
every thing on the hame page is froozen
Add a comment
Hi,
Thank you, it works!
Add a comment
hi there this is malou i have a question.my samsung galaxy s suddenly is hanging i cannot open its saying is stopped unexpectedly please try again.force close what is the meaning of that..please can you help me.thank you very much...more power...
Add a comment
malou,
follow walter's the instruction
Add a comment
Will this erase your pics?
Add a comment
how long to reset
getting the same problem..my tab still hang..plz help me
Add a comment
pls sir help to my samsung galaxy mini,,still hang..wat will i do?
Add a comment
have a question.my samsung galaxy mini suddenly is hanging i cannot open its saying is stopped unexpectedly please try again.force close what is the meaning of that..please can you help me.thank you
Add a comment
frozen completely
Add a comment
it appear that SORRY the application Samsung Home ( process com.sec.android.app.twlauncher ) has stopped unexpectedly . please try again . everytime i unlock my phone
Add a comment
I downloaded this app call cycamera and it completely froze my phone. So I turned it off and turned to back on to tried to solve the problem. But then when I turned it back on,all it appears are those force close messages. The background is also black. I tried factory reset it and it still doesn't solve the problem, I need some help here!
Add a comment
the recovery screen wont appear and i'm still Getting the same problem saying Sorry The application Samsung Home (process com.sec.android.app.twlauncher) has stopped unexpectedly
1 Comment:
what do i do
by
Add a comment
application samsung home has stop unexpectly
Add a comment
Hi there,
My tablet hung up, then dead. I tired the procedure to press power and volume buttons, the recovery screen wont appear.
It is still black and no message or recovery mode that I can see.
Can you tell me what should I do as earlier it was working properly and suddenly hung up and dead.
Many Thanks
Luisa
Add a comment
error message: Sorry! The application Samsung Home (process com.sec.android.app.twlauncher)has stopped unexpectedly. Please try again.
can any one plz help to fix this problem in my Galaxy Tab 1000
Add a comment
no I just put it in my bag to go to the pool and when I took it out it was frozen black background with only the word Samsung on the screen I pressed all the buttons but nothing moves
Add a comment
i was playing candy crush yesterday then suddenly it stopped and i can't turn it off even i pressing its switch off button. then after few hours its screen was blocked and now i can't force it ti open.
hope for your immediate answer!
thank you!
Add a comment
See the video in above link to force close the mobile also advice that it help or not.??
Add a comment
To Walter Galan - thank you SO much for your advice. It worked and was so easy (I am no techie). Thanks again.
Add a comment
nothing happens after i've done factory reset :(
Add a comment
Dropped but not hard
Add a comment
The whole screen is completely frozen in Arca
Max Comics, Blondie cartoon. It wont shutdown either
Add a comment
my tab has just cot samsung stuck on sreen turned it of and back on but still doing same any one help
Add a comment
I had just turned on my tablet and it turned off and won't turn on again. It happened this past summer and had it repaired and now it's happened again only a couple of months later.
Add a comment
it wont charg
Add a comment
the screen is frozen, I can do anything
Add a comment
Any drop
Add a comment
All stopped . it says 'The application Samsung Home( process com.sec.andriod.app.twlauncher ) has stopped unexpectedly. Plese try again.' Pls Help.
Add a comment
my samsung galaxy tab 2 hanged and stopped unexpectedly and now its not starting at all! what to do? I joined it through usb port to my pc still its not starting and working at all? please help me to save all my important data is in device
Update
My samsung galaxy tab 2 is hanged and stopped and not starting at all! I tried to join it to my pc through USB port still it's responding! please help me my all important data is there
Update
HELP PLEASE! ANYONE OUT THERE??????
Add a comment
Add a comment
My Samsung tablet stopped about three years ago. It has not been turn on on two years. Now I can't get any of my app's to work at all
Add a comment
aplication has stopped
Add a comment
I do n't open Samsung Galaxy Been. when i open the phone a one message (Sorry! the application twlauncher has stopped unexpectedly. please try again. what can i salve this problem.
Add a comment
Un install and open the phone again
Add a comment
Add your answer
hamzani will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 15
Past 30 Days: 54
All Time: 62,703
