A digital TV converter box by Apex Digital.
Power Light won't stay on
Apex DT502 digital converter box is hooked up. But when I press the “ON” button — either from the remote or on the box itself — the light turns from red to green, then immediately back to red. It won’t stay green at all. If I press and hold the power button on the box, it just flashes red. Any solutions?
Add a comment
1 Answer
Hi,
It seems as though it is either going into some sort of protect mode or perhaps there is a problem with the power supply in the box.
I cannot find a service manual or schematic for the box online so you may just have to open the box and initially check the power board for any obvious component damage such as heat stressed components, bulging or blown capacitors and dry solder joints on the back of the board.
Here’s the ifixit Apex Digital DTV Converter Box Power supply Board replacement guide that may or may not be of some help. I don’t think that it is the same model as yours (possibly a DT-250A?) but hopefully it is similar enough to be of some help.
If you see something wrong and/or you’re not quite sure, post some close up images back here. Here’s how to do this Adding images to an existing question
Apex Digital DTV Converter Box Power Board Image
Guide
Difficulty:
Easy
iFixit Image
Guide
Difficulty:
Very easy
2 - 5 minutes
Add a comment
Add your answer
farmerzdtr will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 15
All Time: 749
