The Mazda Capella was commonly known in markets outside Japan as the Mazda 626. The Mazda 626's sixth-generation was built on the GF platform and released in 1997 for the 1998 model year.
Why the power window doesn't work?
I have a 1999 mazda 626 with a 2.0 L engine and the driver’s side window doesn’t work. How can I check to see if the switch is bad or maybe the motor?
Thanks for your help,
James
Orlando, Florida
Add a comment
1 Answer
Chosen Solution
Hi @matusalen64 ,
Don’t know if the following will be a help or not but here’s the 04/97 Mazda 626 Workshop Manual (I couldn’t find the manual for the ‘99 model).
Scroll down and click on Body. When it opens on the webpage, scroll to p.S- 9 to view the procedure to test the power windows circuits etc.
It is easier to use the guide if you download the file by using the download link found at the top right of the document header bar.
Hopefully it will be of some help.
Score 2
Add a comment
Add your answer
James will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 6
Past 30 Days: 23
All Time: 983
