Up to 20% off select tools
Model A1059 or A1099 / 20, 40, or 60 GB hard drive / touch sensitive click wheel
Why doesn't it work when unplugged?
It works when plugged into pc. It shows a full charge but doesn't turn on when unplugged. What is wrong? How can I fix it?
Score 2
Add a comment
Most Helpful Answer
Sounds like replacing the battery would solve the problem.
Score 3
Add a comment
I had a very similar problem. The charge on my 4th Gen Photo battery would last less than 30 min. before completely depleted. In addition, I would plug in the firewire charger into a wall outlet noting that the date and time would reset to Jan 01, 2000 0000hrs. I did not lose any on my tunes. Thus I only listened to it if I was able to plug in in to an outlet somewhere.
After seeing the replace battery suggestion noted above, I did just that. I disassembled my iPod and discovered that the battery within was bulging from the center --- (I had a similar problem with a cell phone battery that fail to maintain a charge) --- swapped out the batteries, charged it up and have not had a problem since. With the proper tools I had purchased here at iFixit (yes, you need the spudger to remove the old battery), my total repair time was less than one hour.
Add a comment
hi, mi I pod got stuck on one song and it will not turn off or change to any tracks, what could be wrong
1 Comment:
please start a new post- just ask a question :)
by Share
Add a comment
Have you tried a soft reset first to get back to the startup screen?
Add a comment
My iPod will turn on if plugged into the Bose Dock player but will not if held in hand
Add a comment
After charging with PC USB it got stuck with eject option. But nothing is happening with My Apple IPOD just showing msg eject before remove.
Please help
Add a comment
tell me what i cant do
Add a comment
Add your answer
cindy will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 14
All Time: 3,669
