A 14'' touch-screen laptop created in 2014 by Toshiba
Can't get to power on
Laptop won’t power on
have 19v at the power cord
Adaptor shows 19v
I have a orange light that indicates battery/plugged in status
-it is flashing orange
Power button flashes once when pushed, but no fan spin or post
Google search reveals very little
Any ideas?
3 Comments:
Hi @bvansick
Normally you will need laptop schematics to check on the mainboard,
e.g. if power is supplied correctly, etc from voltage regulator, MOSFET, etc
by
So I'm not sure what I did, but I put it back together and was able to get it on. I wonder if there was some kind of short in the DC power receptacle that I have temporarily fixed when I put it back together.
by
@bvansick
You probably just didn't connect something correctly first time.
Did you clean out dust?
by
Add a comment
1 Answer
Hi @bvansick
As you said "Power button flashes once when pushed, but no fan spin"
My guess is your laptop isn't getting the right electricity, it might be your power supply problem.
Did you take it to any service center?
(Note: Max time we use our laptop by plugging the charger. The power supply may be damaged due to this. So remember, try to use it after unplugging the charger every time.)
Add a comment
Add your answer
Brentt VanSickle will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 23
All Time: 395
