Released in 1999, successor to the original PowerMac G3, 300-450 MHz, 64 or 128 MB of RAM, 6 or 12 GB HDD
won't power on
Hello!
I am also having the same problem. I did what u suggested and nothing. I opened the computer and I noticed that 1 of the plugs P5 was not connected to anything. My question is should that part be connected and if so where? Maybe that is what is causing my G3 not to power up?
Thank you.
Edie
1 Comment
Please start a new question as this one has been answered and almost no one will now look at it. Thanks
by
Add a comment
1 Answer
Chosen Solution
The Plug "P5" is just another 4-Pin Molex power connector. It is used to power a secondary hard drive, and doesn't need to be connected to anything for the computer to work. If the computer isn't powering on, a bad power supply may be to blame. The PowerMac G3 Blue and White (as opposed to newer/older powermacs) uses a standard PC "ATX" power supply. You can buy these at just about any store that sells PC parts, or use an existing one if you happen to have one handy.
Score 2
Add a comment
Add your answer
edith will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 17
All Time: 1,490
