The Pocophone F1 is a mid-tier smartphone made by Xiaomi Inc, announced on 22 August 2018 in New Delhi, India.
Yellow stress marks on cracked screen
I dropped my phone and it cracked but touch worked fine,after a bit i noticed that it had some yellow spots that wouldnt go away,and some that show up around the cracks only when i press hard on it.
Should i only replace the top glass cover or should i replace the whole lcd screen and digitizer.
Score 2
1 Comment
Force reboot your smartphone this will solve your problem.
Poco x3 pro screen flickering, Poco white screen/ Yellow screen problem solution
This will help you
by
Add a comment
Chosen Solution
I'd recommend just replacing the entire screen. Most likely you'd break the screen anyways when replacing the glass as that part on a screen isn't exactly designed to be removed. An entire screen replacement is pretty much necessary unless you're a professional phone fixer.
Score 2
1 Comment:
Sir i have an issue
My phone screen is cracked and it shows yellowish color around crack
My touch work all well but when i put a bit pressure on screen the touch becomes unresponsive for a while
Can it b fixed by replacing glass only?
by
Add a comment
Hope this will help you
https://howtofixgadgets.com/poco-x3-pro-...
Score 1
1 Comment:
Im having the same problem I'm not gonna state my age but I'm younger than 18 so me and my friends were playing with pvc pipes and they were huge pvc pipes about 20-30 ft and one of my friends dropped one of them and it landed on my phone and cracked the screen now around the crack is yellow and my mom and dad said if I ever break my phone which is only 6 months old that Im not getting a new one until my birthday which is in August
by
Add a comment
If it doesn't interfere with what you're doing then it probably be fine leaving it but if it bothers you then I probably get a new screen and check that the internals aren't damaged
Add a comment
Add your answer
zulul will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 5
Past 30 Days: 45
All Time: 16,667
