Up to 20% off select tools
Released in 2012, the Asus N76VZ is a 17-inch laptop with a screen resolution of 1600x900 pixels or 1920x1080 pixels. It has a 3rd-generation Intel Core i7 processor and an Nvidia graphics card inside.
Why can't remove battery
Hello
I am trying to remove battery on Notebook Asus N76V, but I think it have problem with the slider lock because he is on the wrong position and now it is very hard to remove it, I tried a little force to remove it but I wasn’t able to do it… I searched many solution but I didn’t found the solution.
Edit: it is Asus N76VJ but I think it’s the same way to remove battery.
Add a comment
Most Helpful Answer
It’s likely that the slider to unlock the battery is broken. First try sliding it to the unlocked position and force the battery out. There isn’t much you can do other than replacing the bottom case. I’ve found though that a lot of times if I force it out, it will come out with little damage.
Score 3
Add a comment
with flat head screwdriver,
start to lift battery pack from back ( furthest away from battery open slider )
start to lever from right or left ,,, lever from either corner
This worked for me and i did no damage to mechanism
operate lever and apply some silicon spray
Score 1
1 Comment:
This was actually helpful!
I used a plastic pick and started wiggling and sliding.
I spent more than 30 minutes trying before seeing this tip, and I was so happy that I didn't break anything lol
Thanks
by Share
Add a comment
Add your answer
Mickael Gomes will be eternally grateful.
Past 24 Hours: 4
Past 7 Days: 8
Past 30 Days: 30
All Time: 1,458
