Up to 20% off select tools
Released September 2013, the Gigabyte P34G is a 14" gaming PC laptop with a 4th Generation Intel® Core™ i7-4700HQ Processor (2.4GHz-3.4GHz).
Battery replacement doesn't work
With new battery replacement the icon indicate 100% full charge and when i unplug the charger the pc shutdown!
My charger specification is : output 19.5V ; 7.7A
My battery specification is : Battery Volt: 10.8/11.1V / Battery Capacity: 4300mAh/47.73Wh
My PC is : P34GV2
I buy it here:
http://www.laptop-battery.us/gncc30-giga...
This is the second battery replacement i do because the first was doing the same thing and it was returned
How its possible and what can i do?
1 Comment:
Hello,
now the situation has change…
I have two os in my laptop linux and windows. The first test i do it was to test with my principal os Linux and the result is my first message here.
So i tried to test it on windows and on it, the battery work good with a good charge and discharge ect, but when i boot in linux the laptop won’t boot or run without ac charger and when i unplugged it the, os poweroff suddendly…and the same happen with a live cd.
I don’t understand where is the problem, if is the battery a lot exotical discount fabrication and also that explain the poor compatibility? or there is parameter in bios or others things that i don’t know?…
by Share
Add a comment
“With new battery replacement the icon indicate 100% full charge and when i unplug the charger the pc shutdown!”
2 reasons why you may be experiencing this issue:
  1. both the batteries you purchased my have been faulty.
  2. there is an issue with the motherboard getting power from the battery.
Possible solutions:
  1. replace battery again, if that doesn’t work then
  2. repair the motherboard (although sourcing information and parts may be difficult) or
  3. replace the motherboard
1 Comment:
Hello,
by Share
Add a comment
your must buy a defective item,for your Gigabyte P34GV2 battery please look at our link:
http://www.laptopower.com/GNC-C30?search...
we have 1 year warranty
thanks
Add a comment
If it has one, disconnect the power button board and/or the charging port board, clean the contacts and then reconnect it.
Add a comment
Add your answer
Ki Ko will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 30
All Time: 678
