Repair and additional information for the Frigidaire GLRT183TD*, a top freezer refrigerator with an automatic defrost system and an anti-sweat heater switch, introduced in 2004. This page covers information for model numbers matching the pattern GLRT183TD*.
Why my fridge won't run
I bought a used frigidaire refrigerator, model # GLRT183TDWH, it worked and was cold when I bought it. The gentleman said to lay it down in the bed of my truck for transporting. When I plugged it in it ran for about 30-45 seconds then stopped. The lights are working but it's not running.
I don't have the money for another fridge. Please help!
Add a comment
Most Helpful Answer
The gentleman does not know what he is talking about.
Normally it is ok to transport a refrigeration unit in any orientation. The problem arises when it arrives at its final destination. The refrigeration unit is designed to operate only in the upright position. This has to do with the way refrigerant and lubrication oils settle inside the unit when it is turned off. The system is designed to leak down after it is turned off, so that when the it starts again, the compressor can start easily due to the low pressure on the compressor side of the system. If the unit is started soon after righting it, or while it is on its side, refrigerant may build to high pressure levels immediately upon startup. This is a good way to burn out your compressor. In short, there is no issue with transporting it that way, but it is always recommended to let it sit upright for at least a day before attempting to start it.
Score 2
Add a comment
Chamber leak ho gaya
Add a comment
Add your answer
Dana will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 15
All Time: 380
