Why won't my Ti84 Plus CE turn on?
My calculator will not turn on despite being at full battery (when it charges it has a green light). The screen does not turn on when I press the on button, instead it stays black. I have even bought a replacement battery online, but this did not seem to help. Before, my calculator would often not turn from time to time, but still turned on occasionally, and it always turned on after a few seconds of charging it, but now it does not.
1 Comment
@codyrhodes Do not post AI generated responses. This question already has an accepted answer.
I can tell it's AI generated by the em—dash, the broken formatting, the confidence, and the inaccuracy. Let me debunk your response:
1. "try a reset with the reset button". This is unnecessary, replacing the battery already triggers a full ram reset. The screen getting "stuck off" has never been a thing in the 11 years I've been working with these devices.
2. "adjust contrast". The 2nd+on key combination just turns off the calculator. You can't adjust the contrast on a TI-84 Plus CE, only the brightness. The brightness does not get low enough to look like it's off. The AI is confusing the TI-84 Plus CE's backlit display with the TI-84 Plus's monochrome display.
3. "resintall the OS" this was already in the accepted answer
4. "repair usually isn't worth it". Repair is often not feasible, but successful repair saves over hundred dollars in a new calculator.
by TheLastMillennial
