Repair guides and support for top and front loading Whirlpool brand washers.
Why I can't access diagnostic mode
I installed a new control board and machine won't go into diagnostic mode. What is next step?
Score 4
1 Comment:
What is your model number?
by
Add a comment
Is it a top load with no dial? Cabrio? If so turn it on and unplug and wait till it goes dead ā€œ youll be impressed how longā€ and then wait three minutes, take a screw driver and touch the two flat leads on the plug in together ā€œunplugged of courseā€ then plug it in with the lid down, open the lid for sec or two then close it, used three buttons as like 1,2,3. Press 1,then 2 then 3 in normal sorta motion three times in a row, if it has a dial and the sensing, wash done spin lights under the knob, turn it a few times left, ā€œall the way aroundā€then right. Right. Right. Left. Right. Not to fast not to slow, every fail try, spin left few times again.
Add a comment
Press each button, if you see buttons responding (like LED blink whenever you press a button), this means touch pad or buttons are working. If you became certain that all buttons are responding but unit still won t go to test mode, check door switch, if switch is OK…then it must be the control board.
Add a comment
My whoorlpool top load washer will not go into diag mode no lights will light up only the green light inside on the control board And the pump runs constently
2 Comments:
Hi @philip90310,
What is the model number of the washer?
by
this was EXACT problem but then when I unplugged one of the sensors to test it on the control board i just randomly tried to put it in diagnostics mode and it worked. but I still am not sure what the problem is....according to one video it is the sensor that is bad which does make sense bc it was flashing the sensing green light and humming every 20 min for 5 min intervals
by
Add a comment
Add your answer
Dale Wasinger will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 6
Past 30 Days: 32
All Time: 8,460
