HX9360 can't turn on
I measure the battery about 3.8V.(F1 /R6 point).So I think the battery is fine.
But I push the button can't turn on it.But put into the cup can charge the battery.
So how do I to check the board or more action?
thanks
1 Comment
I have probably a similar issue. Who can find and change a battery here?
by
Add a comment
Most Helpful Answer
swat1230 your voltage maybe fine but it is not a good indication of your battery being okay. It is possible that your battery simply does not hold enough charge to supply the demand. I'd start with a new battery first, then re-evaluate. Check your switch circuitry etc. with your multimeter.
Score 3
Add a comment
I'm having the same problem. Have you fixed it?
Thanks!
Score 1
2 Comments:
I have also checked the switch circuitry, which is fine. Additionally I have also connected an external power supply with 3.8V. Unfortunately it didn't helped.
by
I have exactly the same issues, battery power is still good. Have so. fixed the problem yet?
by
Add a comment
Add your answer
swat1230 will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 27
All Time: 2,568
