Repair and disassembly guides for Sony DVD players.
Load/Eject door will not open, cannot load DVD
Sony CD/DVD Player DVP-SR210P Load/Eject door does not open. It sounds like it is but nothing visable with the cover off is moving. What can I do to fix it?
Score 1
2 Comments
Just fixed mine. Belt for tray eject was stretched & just slipping on the motor pulley. Dug through old bad PC CD/DVD drives & found a belt that fit. Loads & ejects tray like new now.
by
Harbor Freight sells those general purpose O-ring variety packs, there might be one of the size needed in there?? Original drive belts are square, but any rubber O-ring of close size needed should work as long as the problem is not something mechanically jamming the tray.
by
Add a comment
1 Answer
Chosen Solution
A stuck disk tray is fairly common. See https://therestartproject.org/wiki/CD_an...
Score 2
Add a comment
Add your answer
Vickie Belt will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 17
Past 30 Days: 79
All Time: 10,953
