Model number NV370. Stands 27 inches tall and features Shark’s never loses suction technology and swivel steering.
Power Brush won't rotate
First time using the Power Brush on my new Shark Navigator, 5 stairs into it, sounded like it picked up something and the brush quit rotating. I immediately stopped, removed the tool and tried to find what was stuck. I see nothing stuck. I can't even rotate the brush by hand, if attached the belt just slips, with the wheel removed that holds the belt, I still can't get the brush to rotate by hand. I can move it maybe 1/2 inch but that's it. It's locked. The cover will only lift to about 1 o'clock if that makes sense, then it stops. The instruction book looks like it is removable and I might be able to remove it by prying it off the "pegs" on the end, but don't want to break it. Any suggestions?
I was able to get it off the pegs to remove it. I can force turn it a little more, but it still does not turn when the vacuum is on. I tried both settings just to be sure I wasn't using the wrong one. Neither makes the wheel turn.
Add a comment
1 Answer
If your Shark Navigator Lift-Away Pro vacuum’s floor roller no longer spins, see the Shark Navigator Lift-Away Pro Floor Roller is Not Spinning problem page for possible causes and solutions.
1 Comment:
What if non of those work then what
by
Add a comment
Add your answer
J John will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 9
Past 30 Days: 28
All Time: 3,450
