The second generation Integra was introduced in April 1989 and in this generation, one of the first VTEC engines ever manufactured by Honda was installed in a JDM Integra DA series.
My horn don't work
how do i fix my horn?
Score 1
Add a comment
1 Answer
Chosen Solution
traceymckellip start off by applying 12V directly to the horn. Watch the connectors and - goes on ground so anywhere on the horn mount will be fine. If your Horn sounds you know it is good. Then check all of your fuses (we need the proper year to help you out with that) to make sure it is good. Last you can check the horn relay which is located on right hand side on top of the fuses box.
You can also check on the relay if your switch is working. You'll need a simple multimeter for that. Let us know if you have the tools to do so in case you need further help with that.
Score 1
Add a comment
Add your answer
traceymckellip will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 21
All Time: 1,314
