Up to 20% off select tools
Vintage style turntable with modern additions like headphone, CD, and MP3 support.
CD door won't open
'CD door
The door to the CD will not open.
What can I do to open it? When I press the button, the display says 'open,' but it will not.
Score 2
1 Comment
Do you hear anything when you press open?
by Share
Add a comment
Chosen Solution
I presume this is the kind of CD drive with a tray which comes out when you press Eject and that you've tried inserting a straightened out paper clip into the hole in the front panel. I've seen this fault a few times. You need to remove the complete CD drive from the unit and open it up if it's inside a metal case.
I've described how to deal with this fault in the Restart Wiki.
Score 3
Add a comment
I would stick a paper clip in it but where?
2 Comments:
Take a butter knife and GENTLY slide under the CD tray, on the left until you feel the catch release
by Share
Pamela Fowler, Thank you! This worked!!!
by Share
Add a comment
Add your answer
mdsantos will be eternally grateful.
Past 24 Hours: 7
Past 7 Days: 30
Past 30 Days: 157
All Time: 12,077
