Whirlpool Gold Series Dishwashers can be identified by model number WDF750SAYM0, WDF750SAYM1, WDF750SAYM2 or WDF750SAYM3.
Some cycles work, some cycles don't
I'm not sure if this is how to do this, but here's the problem with the dishwasher.
a) the 'clean' light is out so any diagnostics are useless because that's where you get the error code - the blinking Clean light.
b) On Normal, 1Hour, and Sensor, the unit fills with a small amount of water, releases the soap tab, makes a few noises and then goes silent after about 10 minutes. It repeats the process a little later on and then finishes. But the dishes are filthy. On Heavy or if you add a SaniRinse to any of the other cycles, it will run normally.
This makes me think that it is not a mechanical problem but an electronic problem. Especially since there is already a dead LED.
Add a comment
1 Answer
Chosen Solution
Cause 1
Door Latch
The door latch ensures that the dishwasher door latches shut. If the door does not latch properly, the door switch might prevent the dishwasher from running. If the door latch is broken, replace it.
Parts
Door Latch for your WhirlpoolDishwasher
Door Latch - Part # 3198192 Mfg Part # W10619006
RepairClinic Item #3198192
Door latch *Part has been redesigned by the manufacture
$25.64
Quantity:
In Stock ›
Same Day Shipping
Order by 8:00 PM ET, this part ships TODAY!
365-Day Return Policy
Return any item for any reason within 365 days of placing your order.Find out more »
Total: $25.64
ADD TO CART
Cause 2
Main Control Board
The main control board provides power to nearly every component of the dishwasher. If there is a problem with the main control board, it might not send voltage to the dishwasher, causing the dishwasher not to start. Control boards are often misdiagnosed—make sure you check more commonly defective parts before replacing the main control board.
Parts
Main Control Board for your WhirlpoolDishwasher
Main Control Board - Part # 2312646 Mfg Part # W10479764
RepairClinic Item #2312646
Electronic control
$143.80
Quantity:
In Stock ›
Same Day Shipping
Order by 4:30 PM ET, this part ships TODAY!
Total: $143.80
ADD TO CART
https://www.repairclinic.com/RepairHelp/...
Secures the dishwasher door closed to ensure proper operation during wash cycles. Image
Product
Whirlpool Dishwasher Door Latch Assembly - W10619006
$29.99
Manages the key functions and operations of your dishwasher. Image
Product
Whirlpool Control Board - W10479764
$161.99
Score 2
1 Comment:
Thanks, it DOES run for a little bit, but then kind of stops and does not much, then starts up again but not really. When it's on a different cycle though, it works ok (or if I add sani rinse option) so methinks it's the control board (cause#2) yes? If it was the door latch, it would either never work, or have no rhyme or reason, right? Anyways, thank you, this confirms what we thought. I AM eternally grateful :)
by
Add a comment
Add your answer
Candace Snook will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 24
All Time: 2,997
