AC power adapter for MacBook, MacBook Pro, and MacBook Air. Uses a self-aligning magnetic connector that disconnects safely when tugged. First-generation (2006-2012) MagSafe chargers have a slightly thicker, L-shaped connector. Available in 45 W, 60 W, and 85 W versions.
it's showing not charging
Light is ambor indicating it charging, however it's showing not charging. I bought another battery and charger. So frustrated. I cleaned my connectors also. Please anybody have any advice?
2 Comments
Can you give us your systems specs? As I suspect your real issue is within it not the charger.
by
As Dan said, if you bought a new charger and cleaned the connectors, it's likely a problem with your system or battery.
by
Add a comment
1 Answer
Most Helpful Answer
One thing worth trying is getting the (if applicable) mag safe charging port replaced. Generally a cheap way to start a diagnosis.
Score 1
Add a comment
Add your answer
Pva will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 5
Past 30 Days: 15
All Time: 285
