Up to 20% off select tools
The Dell Vostro 1400 is part of a line of small business oriented laptops. The device includes a 14" screen released in July of 2007.
Black screen- What's the problem
My laptop will turn on but there is no display on the screen. I tried turning it off and back on but I had the same issue. What should I do to fix this issue?
Add a comment
1 Answer
Most Helpful Answer
There could be a number of things wrong with your laptop to cause this, it will either be a software or a hardware issue. If you feel capable you can take it apart and check that everything is plugged in right and try again. If that doesn't help you should probably take it in to be looked at.
Score 1
Add a comment
Add your answer
Kennedy Hallmark will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 4
Past 30 Days: 22
All Time: 475
