The Epson Artisan 837 is an all-in-one printer, copier, scanner, and faxer produced by Epson beginning in 2011. Model number C11CB20201.
Why do I have lines when I print?
there are lines when printing black. when I do head cleaning nothing changes.
Score 1
Add a comment
1 Answer
Most Helpful Answer
abigailhechejewels , the lines may be coming from dirty/ink on feed rollers, clean the rollers with soft cloth dampened with 90% Isopropyl Alcohol . Good luck.
Score 1
2 Comments:
cleaned rollers twice still have lines
by
Hi Mr. Bill, it sounds like I have the same problem as you. I tried everything from cleaning nozzles, head alignment and rollers like you did. I think it's going to be an electronics problem that will be very expensive to fix. So my thoughts on it are is probably ending up dumping it to buy a new one but not before I tear the whole thing apart trying to find it. My lines are horizontal throughout every document spaced about an inch apart. Good luck, I will let you know if I find a solution if your problem is the same.
by
Add a comment
Add your answer
abigailhechejewels will be eternally grateful.
Past 24 Hours: 3
Past 7 Days: 8
Past 30 Days: 35
All Time: 928
