Repair guides and support for budget electronics manufacturer Tagital.
Why wont my tablet turn on
it wont charge wunt turn on
Score 1
Add a comment
Chosen Solution
Ann Shipman, There could be a few reasons for your device not charging and powering on. Faulty charger/cable, faulty battery, faulty charge port/connection etc., you could try a factory reset as described in 1st link below. Other links may help in trouble shooting your device if reset does not work. Good luck.
http://www.femitechservices.com/2016/04/...
https://www.youtube.com/watch?v=DSGAHFsn...
Tagital T7X Troubleshooting
Tagital T9X Battery Replacement
Tagital T7X Battery Replacement
Tagital T7X Battery Image
Guide
Difficulty:
Difficult
5 - 10 minutes
Tagital T9X Battery Image
Guide
Difficulty:
Difficult
25 minutes
Score 2
Add a comment
I'd suggest opening up the device and making sure that everything is appropriately Connected to your logic board. if not then find the plug and re connect the cable to the device. If you see nothing wrong with that, see if the charging port is loose, as this is common in low budget devices. If you see nothing wrong with that then I'm sorry, But your tablet had its run.
Add a comment
Add your answer
Ann Shipman will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 26
All Time: 914
